Some mavic mini app issues
12Next >
5834 44 2019-11-14
dronie1965
Flight distance : 24897940 ft
Received the mini today , updated everything and did a small test flight.
I noticed some issues with the fly app( maybe someone already wrote about it)
I noticed the app doesnt remember the rth and the gimbal setting.
Each time you start it up , you have to change it again.
For example rth is set back to 15 m , which is imo very dangerous.
Or does someone has a solution?
2019-11-14
Hi all, we are terribly sorry for the trouble caused, your feedback has been forwarded to our engineers and we have located the issue.
The new APP is estimated to be released next week to optimize this problem. At the moment, please make sure to set the proper RTH Altitude each time when you restart the DJI Fly or the aircraft.
We apologize again for the inconvenience caused and appreciate your patience.
2019-11-15
hallmark007
Flight distance : 9827923 ft
Have you updated FW ?
2019-11-14
dronie1965
hallmark007 Posted at 11-14 12:33
yep , all updated , but auto rth altitude jumps back to 15m .
Also a friend of mine has the same problem.
i tested the gimbal setting again , but I have to correct my previous comment regarding this, the pitch etc is not reset but stays the way I put it (probably before I pressed reset)
but the rth definitely jumps back which is a safety issue
2019-11-14
hallmark007
dronie1965 Posted at 11-14 12:41
Sounds like a glitch .
2019-11-14
Oracle Miata
Flight distance : 3759829 ft
I will report that mine is also doing this...
2019-11-14
dronie1965
Also the aircraft serial number in the app doesnot correspond with the serial number on the drone/box. There is already another post for that, but still like to mention here
2019-11-14
dronie1965
hallmark007 Posted at 11-14 12:53
I am wondering how it comes that these professional dronevloggers and testers havent mention this or brought this forward , as they really should know and found this out with their testing. Maybe the beta versions didnot have this issue that could be a possibility.
2019-11-14
Juliflash
Flight distance : 2923 ft
Im sure these guys are overwhelmed with feature requests and testing, and a bit of patience may be needed.
They did not expect the demand for sure, so let's hope things improve soon, for you and everyone.
Best,
2019-11-14
DJI Paladin
Flight distance : 318 ft
Hi, I am sorry for the trouble your Mavic Mini has caused. For us to isolate the have you tried a different compatible mobile device? Please keep us posted for further assistance. Thank you.
2019-11-14
dronie1965
DJI Paladin Posted at 11-14 15:04
hello
I used the iPhone 7 Plus and iPhone X .
a friend of mine used the iPhone 7.
all the same issue rth resets back to 15m .
therefore each time when you start the drone , you have to set the rth again
2019-11-14
hallmark007
dronie1965 Posted at 11-14 13:54
For the beta testers part of their job is to flag these situations, if they are isolated it’s difficult, also if it’s not there they obviously cannot, could it have arisen with last FW, only way to know this is if you can row back, I’m really of no use to you until I get mine, but as soon as I do I will test .
2019-11-14
dronie1965
hallmark007 Posted at 11-14 15:18
cheers ,
oh tomorrow a big day for you. have fun
2019-11-14
DJI Paladin
dronie1965 Posted at 11-14 15:17
hello
Thank you for the additional information, For us to be able to better assists you, If possible, kindly please provide a video of the RTH and Gimbal settings concern. Thank you.
2019-11-14
Oracle Miata
Juliflash Posted at 11-14 14:34
Best,
Respectfully, I'm pretty sure they were aware of the demand.  They created the demand.
2019-11-14
WSUPolar
Flight distance : 2241375 ft
Mine does this as well - I’ll attempt some screenshots - happens after every battery change - even when leaving the Go Fly app open the whole time.
2019-11-14
miniger
15m bug confirmed for iPhone 6 (iOS 12.xx) as well.
2019-11-15
kev001
Flight distance : 251778 ft
RTH image transmission error for my first flight - Samsung S6 -- latest app -  looking for a fix
2019-11-15
Juliflash
miniger Posted at 11-15 00:19
I plan on using an iPhone 6, it seems is more of an App bug rather than happening only to some phones.
Lets see how long for a fix.
2019-11-15
miniger
Yes indeed, iPhone6 is working fine during flight with MM. Even with video cash. But its hard for my fingers with this tiny screen ;-)
2019-11-15
dronie1965
Maybe also check if the battery of the phone is drained very quickly. I am using the iphone 7 plus and it looked like the battery went down very quickly. Have to do some more tests and keep an eye on that one
2019-11-15
Oracle Miata Posted at 11-14 12:57
Hi Oracle Miata, please check my post on 2#, sorry for the inconvenience caused.
2019-11-15
Hi miniger, please check my post on 2#, sorry for the inconvenience caused.
2019-11-15
WSUPolar Posted at 11-14 17:25
Hi WSUPolar, we've been aware of it and will get it fixed soon, please check my post in 2#.
2019-11-15
hallmark007
Thanks for the heads up , looks like it will get sorted next week .
2019-11-15
emaneg
Flight distance : 1591 ft
hello administrator, you announced in your post #2 a new app release next week. Will you make available a fly release usable on 32-bit cell phones (or a dji go v.4 release working on MINI as well) or nothing similar is  in DJI plans?
Tks
2019-11-15
Oracle Miata
DJI Mindy Posted at 11-15 05:14
Thank you for your attention on this.
2019-11-15
hallmark007
Oracle Miata Posted at 11-15 05:42
Just on this , I managed to test, set Rth to 30 metre, clicked Rth craft raised to 30m flew home, turned off craft and RC, turned back on app reset to 15 m , so flew out altitude 12 m pressed Rth and although app was now reset at 15m but craft continued to climb to my original setting of 30m , I only had one opportunity to test this I will weather permitting test again tomorrow, but it’s very strange .
2019-11-15
Juliflash
hallmark007 Posted at 11-15 11:46
Looking forward to know wome more on this, very strange behaviour.
2019-11-15
grahamjohnson10
Flight distance : 2817172 ft
Best,
OMG I have been trying to get to the bottom of this problem.
I have just noticed that DJI FLY App is not available via Goggles App store it downloads as an API file to the computer.
This is not looking good.
OBTW the Apple IOS is still there on Apple.
2019-11-15
grahamjohnson10
Maybe companies like DJI should not target only YT influencers but beta test their products with normal people.
I'm totally dumbfounded how the product was released to the public.
Better transparency would also help.
2019-11-15
Mavic_South_Oz
Yes, this has been discussed a fair bit in the Mavic Pilots forum.
It seems to be an IOS thing, for Android users the RTH saves, with IOS it defaults back to 15m / 40'.
You are using IOS, aren't you . . .
The other 'bug' with IOS, is that the Safety settings - Advanced, it doesn't show the options for failsafe (loss of signal) on IOS, for hover and land, only RTH, but does on Android.
You can picture this . . . under a tree canopy, or inside an old building, and for some reason signal drops, after 11 seconds it will RTH.
With no obsatcle avoidance !
Loss of connection / hover is just great to have, in fact a must have for small drones where people will likely use them for tight flying.
2019-11-15
Big Rich O
Just received my mini today but the Fly app will not install on my LG K20 (VS501) with Android 7. Is there a list that the developers have to test/fix supported phones?
2019-11-15
Juliflash
Big Rich O Posted at 11-15 20:56
Of course there is a list of compatible devices but nothing else.
2019-11-16
kev001
IPhone 6 issue confirmed, RTH resets to 15 - more worryingly the app has crashed mid flight on all my flights when it goes out of range (100m) so far!   You then run the risk of the drone RTHing into something during auto return home.   CONCERNING!
2019-11-16
hallmark007
kev001 Posted at 11-16 03:07
I have checked that Rth anomaly, yes in your app it reverts back to 15m, but if you have set it at say 30m it will fly to that height even though app says 15 and then will Rth , so it’s only a problem with app resetting craft will not reset unless you go back to app and reset it.
2019-11-16
fans7df02dd5
ive got a better issue if the rc disconnects the drone hovers and wont return to home.. what i found is if you try an ipad it wont work with a aftermarket cable the connector is loose but with the stock connector its prolly fine i had to spend 150 bucks to get a iphone 7 its on the way.. my rc said disconnect and for 5 minutes it sat 500 feet away now if your are over a building guess what the remote control wont work if this happens it came back but only after 5 minutes and jiggling the cable... so dji you need to ad return to home on remote disconnect etc.. also the
2019-11-16
fans7df02dd5
yea i noticed mine to saying 50 feet rth and i set 120 then it says  50.. so i have to manaulyl fly it home or know how tall something is.. which i do
2019-11-16
Big Rich O
Juliflash Posted at 11-16 02:35
Let me rephrase that; Do the developers have a list of additional phones to add to the list?
2019-11-19
Juliflash
Big Rich O Posted at 11-19 20:46
Aha Ok I see, they must have and must be fine tuning the app so more phones can be added to the official list.
2019-11-19
12Next >
