Matthew Dobrski
Flight distance : 1831050 ft
gnirtS Posted at 11-20 04:30
Depends on the dynamic range of the shot.
The M2 has fairly limited range so some scenes absolutely require AEB combined with it to not burn things out. The M2P is signficantly better than M1 but still at the end of the day has a small,limited range sensor.
For me the biggest drawbacks of auto-pano mode are (i) it always shoots with horizon centred which is usually what you'd never want and (ii) you lack the ability to select the field of view required.
"Depends on the dynamic range of the shot."
Depends on a workflow you decided to employ when dealing with panoramic photography. Although AEB approach is a must for JPEG format of rough files, DNG is offering wildly wide range of adjustments during files preparation. It's definitely more tedious approach, but offering way more options to tweak files to your liking before importing them into stitching software.
"For me the biggest drawbacks of auto-pano mode are (i) it always shoots with horizon centred which is usually what you'd never want and (ii) you lack the ability to select the field of view required."
(i) - I'm not sure about other models of DJI pocket-size drones, but for Mavic 2 Pro the Go4 app is allowing to tilt the camera to center on target first and start shooting around for a total of 3x3 images.
(ii) - This statement is confusing. The best camera position for landscape photography is always a guess, but pano mode will guarantee proper spacing and overlapping. The efficiency of auto mode will allow for several alternative sequences shot at different positions and angles with single battery.
