Bashy
Flight distance : 2354357 ft
I think ya prob right about hitting something, the drone was 60m above take off point at the time of lost communications
The ground at the Rock of Cashel is nearly 40m above the lower ground from your direction, at around 129m asl.
The area of lost contact was 112m asl, this is just speculation based you taking off lower than the castle grounds.
So in your search area, dont base your search on high trees as you have indicated, you really need to look at all objects
in that area as they all would be high relative to your take off position.
Also take into consideration that it may not have hit something initially, going behind the castle would have caused it to lose contactTherefore it may have travelled a little furth along that trajectory befroe initiating the lost contact senario, RTH, Hover or land
PS, i dont know castle or area, i notices you was in Ireland, so i did a search of Irish castles and found it that way, i then used this site
to find the height of the corresponding areas.
Bear in mind that it may have even been picked up....
