Mavic Mini Care S/N
5126 11 2019-11-16
fans83b350f9
Flight distance : 7001 ft
Hungary
Hi,
I bought a Mavic Mini a few days ago. I purchased DJI Care at the Dji Store before it was activated drone. Is it a problem that i did not enter the aircraft serial number when activating care? I gave the serial number on the box. I typed the serial number on the box on the Care page.
Unfortunately, the mavic mini body has no serial number written on it.
Only Aircraft S/N appears in the DJI FLY application.
Thanks for your help!
2019-11-16
fans83b350f9
Hungary
Does DJI Care apply even if I activated Care with the serial number on the box?
2019-11-16
fans83b350f9
Hungary
https://forum.dji.com/thread-201878-1-1.html
I would have the same question for me. Which serial number to activate care for. Battery cover+box SN same, or DJI FLY APP About Aircraft S/N?
2019-11-16
hallmark007
Flight distance : 9827923 ft
I tried to type in SN in the app, wouldn’t work, had to use SN on the box .
2019-11-16
JodyB
Flight distance : 302536 ft
As fans83b350f9 pointed out, the S/N on the body is located inside the battery compartment.
2019-11-16
BobB
Flight distance : 138310 ft
I received an email from DJI with the serial number from the box attached to the DJI Care contract. They already knew the serial number on the box before it shipped in other words.
2019-11-16
fans83b350f9
Hungary
The serial number on the box is the same as that on the battery cover. The DJI FLY app for Aircraft S/N is a different number.
2019-11-16
dronespilot
Flight distance : 1392995 ft
fans83b350f9 Posted at 11-16 04:23
Yes. You should have received an email with the DJI Care Agreement. Have you received an email?
2019-11-16
that_HMMWV_guy
Flight distance : 59511 ft
The S/N on the box will match the S/N in the battery cover. The Aircraft S/N in the app will be different. DJI told me that when activating DJI Care Refresh you use the Box/Battery cover S/N.
2019-11-16
fans83b350f9
Hungary
that_HMMWV_guy Posted at 11-16 06:17
Okay thank you! Then everything is fine!
dronespilot
Yes I got an email.
2019-11-16
Sick Dawg
Flight distance : 451119 ft
DJI Care serial is in the email you receive from DJI after purchasing Care
at least it was for me.
2019-11-16
DJI Gamora
Hi, thank you for reaching out. Can you please clarify if the problem was already been resolved? Also, you can check your active DJI Care Refresh service plan using the link below. Please keep us posted. Thank you!
https://repair.dji.com/en/djicare/coverage
2019-11-16
