Juliflash
Flight distance : 2923 ft
dronie1965 Posted at 11-16 07:39
I had that also with the mavic platinum. The problem is that the bottom vision sensors cannot detect proper underground, like swimmingpool has a monoteous underground blue when flying low. Also for example snow or sometimes grass. If you check the manual its written in there that flying over monoteous underground can cause problems if flying low . So it can mixup the bottomsensors
Yep, the manual has a section for those surfaces, many to actually take in to consideration since if it cannot see with the bottom sensors it may try to go up. I place it here for a quick reference:
- The Vision System may not function properly when the aircraft is flying over water or snow-covered areas.
- Note that the Vision System may not function properly when the aircraft is flying too fast. Fly with caution when flying at over 10 m/s (32.8 ft/s) at 2 m (6.6 ft) or over 5 m/s (16.4 ft) at 1 m (3.3 ft).
- The Vision System cannot work properly over surfaces that do not have clear pattern variations.
- The Vision System cannot work properly in any of the following situations. Operate the aircraft cautiously.
a. Flying over monochrome surfaces (e.g., pure black, pure white, pure green).
b. Flying over highly reflective surfaces.
c. Flying over water or transparent surfaces.
d. Flying over moving surfaces or objects.
e. Flying in an area where the lighting changes frequently or drastically.
f. Flying over extremely dark (< 10 lux) or bright (> 40,000 lux) surfaces.
g. Flying over surfaces that strongly reflect or absorb infrared waves (e.g., mirrors).
h. Flying over surfaces without clear patterns or texture.
i. Flying over surfaces with repeating identical patterns or textures (e.g., tiles with the same design).
j. Flying over obstacles with small surface areas (e.g., tree branches).
- Keep the sensors clean at all times. DO NOT tamper with the sensors. DO NOT use the aircraft in environment with dust and humidity. DO NOT obstruct the Infrared Sensing System |
