Cetacean
Flight distance : 2528264 ft
Aloha Om,
Will a tweezer fit in and around the rice? You can grind down the sides of a tweezer so that it is as narrow as you need. BTW, that narrow tweezer will still be very useful. My ground down pointy tweezer is one of my go-to tools. I also have sharpened paper clip tips or sharpened them into a slot-head screw driver. Those will easily break up a grain of rice. Grinders and files are great tools for making very small tools.
As noted, the rice can also be crushed or carved with a sharp or pointed tool. If you can break the rice or drill the rice, it will come out easier. You do not have to press very hard to break it up. Then the other suggestions will be more helpful.
Finally, always put the rice in a cloth or paper bag when you use it as a desiccant. If you seal off the volume you are trying to dry, it will be just as effective.
Hope this helps!
Aloha and Drone on! |
