Iphone 6 - DJI Fly - Not optimised for a screen size
1854 7 2019-11-20
Buffalosoldier
Flight distance : 3 ft
It looks like the app is not optymised for IPhone 6 screen, when you open the options the panel takes 99.9% of the screen, it is nearly impossible to exit the options panel unless you very precisely tap on this little strip on the left hand side. It's even worst when you try to use one of the quick shot options, the instructions don't fit on the screen and it is nearly impossible to exit quick shot mode.
2019-11-20
Montfrooij
Flight distance : 2560453 ft
Too bad devs usually work with bigger screens in mind.
2019-11-20
Buffalosoldier
I think I had a zoomed view enabled.. now it's looking much better!
2019-11-20
Juliflash
Flight distance : 2923 ft
Buffalosoldier Posted at 11-20 03:55
Hello Buffalosoldier,
How do you enable/disable zoomed view?
2019-11-20
Buffalosoldier
In options where you have Wallpaper Settings, you can choose normal or zoomed..
2019-11-20
DJI Paladin
Flight distance : 318 ft
Hi. I am sorry for the trouble the DJI Fly application has caused. With regards to the DJI Fly application. To isolate the issue have you tried to uninstall and reinstall the said application? If possible please try to use a different compatible device to check if this issue is still persists. Please keep us posted for further assistance. Thank you..
2019-11-20
andrei193
Flight distance : 240856 ft
Romania
I was just about to make a post regarding this. I have an Iphone 6s and I have this problem also and indeed is because I have the zoom option enabled. If I disable the zoom function everything works as it should. DJI please optimize the app for the zoom iOS setting.
2019-11-20
kristof1840
Flight distance : 13077 ft
Hungary
I have an error too. i cant change the video resolution as u can see on the picture.
2019-12-27
