AlansDronePics
Flight distance : 814751 ft
I can understand the desire to produce a video in 4K if most of the key footage is 4K and other parts have a lower resolution or possibly stills are included. I never imagined this was an actual issue requiring a tutorial.
The real issue might be where there are differing frame sizes within the mix. The black border is easily resolved by using the zoom tool.
Take the case where most of the clips are of the desired frame size. Only those with the wrong size need be adjusted to fit the frame.
Ultimately, when you have made your adjustments, you complete your video in whatever resolution you choose. This step isn't one you need to worry about.
To futureproof footage, generally shoot at the highest resolution. It might not be the best output right now, but with AI solutions in development, it won't be long before tweaking this way is the normal method.
Even Adobe elements can colourise b&w photos these days, just think, those early pioneers must have yearned for a way to create colour pic |
