Manes F
Good night Everybody:
I am experiencing some troubles with M210RTK V2 and Cristalsky. I need to export missions and I can do it to the SD cards. However, I have tried all kind of USB devices formatted with all the possible systems FAT, EXFAT, NTS and, although I can copy and paste on them using the android explorer of Cristalsky when trying to export the mission KML file, the USB device does not appear in the menu. Is it impossible for any reason or I am doing something wrong?
Moreover, I have not been able to connect a 4G USB modem to receive Differential Corrections from our GNNS network. I am able to connect to the caster via WIFI but the modem does not allow me to use the menu for cellular connection. I have seen a video in other thread where someone mentioned that only two specific Huawei modems worked. Could anybody tell me if there is any specif problem with the USB port in Cristalsky that might cause both problems?
I am using the latest version of both, Cristalsky firmware and DJI PILOT.
Thank you so much!
Manés
