I am a new drone owner and I noticed some stuttering of the video that I took after I downloaded the videos after my first flight. I olny happens when I pan the drone quickly left or right. I am using a U1 Lexar 633x sd card that's 4 years old. Other than that the drone is perfect. Do you think I need a new U3 sd card? I was thinking that the old card is not fast enough although it's one of the recommended sd cards on the list for the Mavic Mini.
Hello and good day. I am sorry to know that you are having issues with the videos you have filmed using your DJI Mavic Mini. Are you able to use a different suggested SD Card to see if the issue will still persists. For reference I will be posting the list of suggested SD cards for the DJI Mavic Mini. In addition are you able to please post a sample video of the said issue for us to see and assists you further. Thank you.
Hi, thank you for reaching out and we do apologize for the inconvenience. Can you please send us a video sample showing the problem and it must came from SD card. Please keep us posted. Thank you!
Hi there, I have a similar issue. I uploaded one of the samples on youtube for you to have a look. I don't know why it says I don't have permission to share link, but if you need the link then try below by removing spaces -
h t t p s : / / y o u t u . b e / r A I A w 0 0 e R C k
I used the recommended SanDisk Extreme card recommended for 4k recording, but since Mavic Mini is 2.7k, it shouldn't be an issue. I have used the same card in Go Pro and shot in 4k but haven't seen any sutter there so probably it is not a card issue.
My Mavic Mini's firmware is upgraded to the latest version as well.
I have many more videos with sutter and can upload if you need.
Thanks
When you see 'stuttering', it will be due to either the playback app or the hardware of your computer being to slow for the job. It is NEVER the speed of the SD cad, as the process of recording to an SD card can NEVER drop frames, it is a continuous MPEG stream file, and it either keeps up with the process, or it stops completely.
Very often, shooting video in 2.7 30 / 25fps or 1080p stuttering. How can this be fixed? I use the recommended microSD card (SanDisk Extreme SDSQXAF-032G-GN6MA) and good hardware PC/Smartphone, video shutting even on iphone 11 pro max.
I attached a link to the video below, please download and watch it. https://www.dropbox.com/s/e5yzr8j02za197m/org_86d17b87799adf20_1581771224000.mp4?dl=0
I have the same problem. Video is sttutering at 2.7k captures (especially yaw turnings). This is annoying . Also %100 not involved with read write speed of sd card.
Try going frame by frame on your PLAYBACK device. It is likely a playback machine issue, not a recording problem.
Not dropping any frame doesn't ensures you have a smooth playback. It can happen from time to time that frames are presented sooner or later in their relative timeframe, that can also give a perception of stuttering.
For what I could see 1080 is more hardware accelerated than 4K in my machine. But I am not on fresh hardware and my system isn't up to date.
Really would need to see your video clip. Don't think its the sd card. either playback on a crappy computer, or. like in my latest video, you're too far out.
We really need more info like ,
how far out were you flying?
did you have plenty of satellites?
Anything like this?
