arian_srf
Flight distance : 51358 ft
Iran
Hi
some how I have your problem , I was flying in snow , Extreme fog in mountains ( first time in fog ) , as usual it said low gps be careful , high altitude ( I had 5 or 6 flies there before ) every thing was normal .
it was the first fly after the firmware update 1.0.0.4 , so as soon as it took off , It went up 7 or 8 meters the nstarted to land slowly ( I think it was due to fog ) so I tried couple of times and it slowly landed on snow ( a little snow at the bottom and sd card was wet so I dried the sd card and it said the IMU needs do be calibrated, GPS module error, Gimbal unable to connect and etc.. (codes 40012, 30050, 30047, 30049, 30007) .
so with the drone in my hand started filming ( didn't want to fly in that condintion ) . the gimbal was working and tilting . after the 10 min gimbal was not working so I turned the drone off .
it has been 4 days .
I tried to recalibrate THE Compass calibration is not working , when I press calibrate it does nothing .
i calibrated the IMU ( but after restart the error will come back .)
the gimbal calibration will stuck on 10%
i dont know its a software problem or hardware !? cause it landed ok ! and every thing looked ok .
P.N : the gimbal is moving at drone start . its ok .
i get the gps satellites so I think its ok .
compass is a different part from gps and imu ? could it be broken ? where is it located ? is there a way to reset to factory settings ?
i tried to downgrade to 1.0.0.2 , but the problem still remains .
would appreciate any help . thanks . |
