4k shutter speed
1021 5 2015-6-11
GoDrone.me
Flight distance : 45928 ft
Malta
Doing something wrong, what settings are you guys using? auto white balance? landscape? colour?
2015-6-11
john.lambert4
To be honest I've only ever recorded video using default settings (in LOG mode).  All I can suggest is in order to reduce the "stuttering" in the video when panning is to slow the panning speed down.  Slower is better.  Shutter speed can't really be reduced unless you can attach an ND filter to the lens, otherwise it would be overexposed in bright conditions.
2015-6-11
Oliver
What's the problem? The stuttering water at the end of the shot is a limitation of the P3P. The compression is very poor.
2015-6-11
GoDrone.me
Malta
Indeed the stuttering of the rocks during the panning, really didn't think I was going that fast.
2015-6-11
Daninho
Flight distance : 70203 ft
Yes slower movements help
2015-6-12
aburkefl
Flight distance : 78612 ft
GoDrone.me Posted at 2015-6-12 13:28
In addition to the P3P I also have a Blade 350 QX3. I initially bought it without a camera (in the BNF mode it came with a fixed mount for a GoPro) but quickly became disillusioned with the lack of stability in the video. If you can shoot long stretches without too much agility by the quad, it's not too bad. Otherwise, it's virtually unusable. So I ultimately broke down and bought the CG02 camera/gimbal.
Just prior to that decision, I had ordered and received my P3P. I was disappointed that I just couldn't seem to rotate/turn slowly enough that the panning was herky-jerky or just too fast. I was lamenting the purchase of the CG02 by then. I figured if the P3P was like it was, the Blade would be even worse. Lo and behold, it isn't!
Using the same slow, careful movements I used with the P3P, I shot some test video with the Blade and CG02 combo - wow! It was very watchable, pretty smooth if I dare say so. The CG02 doesn't have any settings. Everything is preset, auto, etc. You have to have a small mobile app to run the shutter - you can interrupt the video with a still and immediately continue the video. Other than that, you can start/stop the camera and remotely control the camera tilt. So, for the true pro (or the serious amateur) there's nothing to adjust, so there's darn little flexibility.
Maybe there's still just too much light getting into the camera. Eventually, when the ND filters become widely available and I can alter a few more settings on the camera - maybe some of that non-smoothness can be alleviated. If I move any slower, the snails will pass me by!
2015-6-12
