remote controller constant beep
1234Next >
28112 139 2019-11-23
creazionivideo
Flight distance : 1126345 ft
hi all my remote control of the mavic mini makes a constant beep, I try to calibrate the controller the beep disappears, if I turn off and on again the controller the beep returns and I have to calibrate again, maybe I'm wrong to calibrate the controller?
2019-11-23
DJI Gamora
Hi, thank you for reaching out and we do apologize for the inconvenience. When calibrating the controller please make sure that: You need to calibrate the RC away from any metal objects also while moving the sticks you need also to move the wheel on the controller (gimbal dial) for us to make sure that the calibration will perfectly completed. If the problem persists, kindly please send us a video showing the problem for us to further isolate this concern of yours. Please keep us posted. Thank you for your understanding and support!
2019-11-23
creazionivideo
DJI Gamora Posted at 11-23 11:28
I tried several times to calibrate but it remains so, exceeding 6%, how can I do?  thanks
2019-11-23
aru
Hi there, I also got this problem on my remote control. I have the mavic mini for 2 days now.
Its exact the same behavior.
2019-11-23
aru
2019-11-23
creazionivideo
aru Posted at 11-23 11:52
what should you do?  it's a controller or firmware problem, I just bought it and I couldn't even try it
2019-11-23
aru
creazionivideo Posted at 11-23 12:01
I have read that this problem has already occurred with the previous Mavic models. Its a hardware problem with the Potentiometer (https://en.wikipedia.org/wiki/Potentiometer). I guess we have to sent the Remote Control in -.-
That's a real impudence....
2019-11-23
creazionivideo
aru Posted at 11-23 12:05
but then what is the purpose of calibration ?, I don't understand
2019-11-23
aru
creazionivideo Posted at 11-23 12:10
it seems that the calibration only lasts as long as you don't switch off the device..
Not sure.
Maybe @DJI Gamora can tell us..
2019-11-23
creazionivideo
thanks dji Gamora, I look forward to your evaluation, if you send my product as a guarantee, thank you
2019-11-23
Lieronet
Flight distance : 809948 ft
Slovakia
Hello, I experienced the same problem too. It was working fine before , but a day ago it started beeping when turned on. Calibrating only helps for one session, after turning of and on the remote again it beeps again. Super annoying. When calibrating the sticks the left one is rock solid , always 0,0 on both axis, but the right one twitches, and jumps, and has a shift about 3 to 6 degrees on each axis. Any permanent resolution? faulty calibration? fw update? already tried to flash the remote with DJI Assistant twice, didn't help .
2019-11-24
djiuser_z75vAD0vVCYk
Flight distance : 111247 ft
Hi all, just had the same annoying problem with controller constantly beeping. I re calibrated the controller about 5 times, in quick succession and it seemed to cure the problems.
Switched it off for a couple of minutes, then was able to fly ok.
Not saying it’s going to cure the problem, mate DJI will come up with a fix.
Cheers graham.
2019-11-24
Hi, just tried my controller after it was off for an hour and it’s constantly beeping again.
I’ve only had the mini for 10 days and it’s a problem I and others could really do without.
Come on dji, sort this out please asap.
Graham.
2019-11-24
creazionivideo
djiuser_z75vAD0vVCYk Posted at 11-24 09:41
but there is no firmware update to solve the problem?  it's a pain to send the drone back to you
2019-11-24
creazionivideo Posted at 11-24 09:59
Hi, have you been advised by DJI to return your drone?
I’m not sure of the last sentence in your reply?
Cheers graham
2019-11-24
Cheers graham
2019-11-24
creazionivideo
djiuser_z75vAD0vVCYk Posted at 11-24 10:31
hello tomorrow I will call the dji, I hope they are fast here in Italy
2019-11-24
creazionivideo Posted at 11-24 10:55
2019-11-24
djiuser_z75vAD0vVCYk Posted at 11-24 11:23
Look forward to hearing from you.
Ta, graham.
2019-11-24
DJI Gamora
creazionivideo Posted at 11-23 11:42
Hi, thank you for the additional information. Can you please clarify if this issue will still persist even you connect your RC to your aircraft and perform the RC calibration? Please keep us posted. Thank you!
2019-11-24
Cepheroh
Flight distance : 1691959 ft
Singapore
Oh man this issue was brought up from mavic air to mavic mini now...I got my mavic air controller replaced the hardware. I thought hardware was improved for the new product.
2019-11-24
creazionivideo
hello but you can't calibrate the RC if the drone is on, you can only do it with the drone turned off
2019-11-24
creazionivideo
DJI Gamora Posted at 11-24 15:57
2019-11-24
Bigplumbs
Flight distance : 620164 ft
Did you get the controller wet or water in the sticks. The issue is when the sticks are not properly centered. Wiggle the sticks about a lot and then see if the issue goes away
2019-11-24
creazionivideo
Bigplumbs Posted at 11-24 23:08
to shake the levers do you want to move them?  or shake the controller simply?
2019-11-24
Hi Big plums, my controller has never been out of the carry case when it’s wet/raining and definitely not flown in the rain, so that’s not the cause.
Looking on you tube this problem existed over a year ago on the MAVIC air. It needs addressing by dji asap.
Graham.
2019-11-24
o4dn
Flight distance : 24524 ft
Hi, I have the same problem, I cannot calibrate the remote controller because the dial has absolutely no effect!
2019-11-25
creazionivideo
o4dn Pubblicato alle 11-25 06:03
Ciao, ho lo stesso problema, non riesco a calibrare il telecomando perché il quadrante non ha assolutamente alcun effetto!
quindi è un problema più esteso, come ti è successo?
2019-11-25
o4dn
creazionivideo Posted at 11-25 06:49
Hi,
This is a brand new MAVIC Mini, out of the box, never used...
I just unboxed the drone, charged the batteries, install the DJI Fly App (I had to purchase a  new smartphone for that!) then I connected the phone to the remote, turn the drone ON, turn the RC ON, and the RC start beeping continuously with the LEDs blinking.
The DJI FLY App request to do the firmware update, which I did, during all that time, the RC kept beeping (very annoying).
Once finished, the RC was still beeping, so I tried the calibration procedure:  I can move the sticks around, it works, but the dial has no effect, as if it was not operating, so the calibration screen stays there waiting for me to activate all the controls, but I can't, the dial button does nothing at all
I can close the calibration screen and return to the app, at  that point the RC stops beeping and the LEDs remain static. But s soon as I turn the RC OFF and ON again, the beeping start again.
That is so annoying... I filed an issue with support@dji.com let's see what they say
2019-11-25
creazionivideo
o4dn Posted at 11-25 07:34
Hi,
emits the beep because the stock is not in the center must be at 0 on all four axes, I have opened a re-entry procedure with dji we hope they answer me, in case I only send the radio control.let me know how it went
2019-11-25
o4dn
creazionivideo Posted at 11-25 07:43
Thanks, I am starting to lose confidence in this thing now ... Looks like so many people report problems... :/
2019-11-25
creazionivideo
o4dn Posted at 11-25 08:14
dji please answer what's happening?
2019-11-25
creazionivideo
this defect is spreading like a leopard, please let us know something we are all worried about
2019-11-25
o4dn
The root cause with mine is different though, the sticks both work fine, the problem is with the dial, it doesn't work at all, hence the failure to calibrate.
The dial does not operate the tilt either, of course...
2019-11-25
Hi Od4n, the wheel for controlling the gimbal tilt works fine on my controller, whilst flying the drone or calibrating it.
But as soon as I power it off, switch back on and we are back to the annoying constant beeping
2019-11-25
o4dn
djiuser_z75vAD0vVCYk Posted at 11-25 10:36
Quick update, I was about to return the device tomorrow but decided for one last try...
And guess what... it worked... The dial worked just fine, I was able complete the calibration, and the remote does not beep anymore.
So it really looks like a software bug to me, it doesn't sound (no pun intended of course!) like hardware (hardware does not automatically repair itself, usually...)
I just hope that remains like that now...
2019-11-25
creazionivideo
o4dn Posted at 11-25 12:05
how did you do maybe I would like to try, thank you
2019-11-25
Bigplumbs
Physically move the sticks about to unstick them inside see if that helps
2019-11-25
Lieronet
Slovakia
I tried the new android app 1.0.2 , calibration again and didn't help. The worst thing is , even when I calibrate before each flight and it stops beeping, it still moves a little in the air, and it wont brake at all when I let the sticks, it drifts thx to ghost input, or miscalibrated sticks. Only the right seems to be bad.
2019-11-26
*DM*
Flight distance : 507087 ft
Of course you never hear about these issues in the paid for/sponsored (read: totally impartial) youtube reviews ... .
Hope you guys can sort it.
2019-11-26
1234Next >
