kiwichrish
New Zealand
Hi-ho..
The exif appears to have the correct altitude in it.
Output from jhead below from one of my images. Other images from that flight have other 'accurate' heights in them.
Note that it's 'File date' not exposure date. Most cameras have a Date/Time field that gives the exposure time, which is my issue as I use a script that uses jhead and re-names the files with a date code, event code and sticks them into folders etc.
FYI: jhead is a command-line linux tool. The command-i function on the mac does not show altitude but does show coordinates and alt-enter on the linux machine doesn't show any GPS data at all. Not sure what windows alt-enter / info would show. Application support for the various tags in exif is variable as well. Adobe products are pretty good mind you, which are obviusly popular.
File name : DJI_0003.JPG
File size : 6553738 bytes
File date : 2015:06:07 16:48:22
Camera make : DJI
Camera model : FC300S
Resolution : 4000 x 3000
Flash used : No
Focal length : 3.6mm (35mm equivalent: 20mm)
Exposure time: 0.0100 s (1/100)
Aperture : f/2.8
ISO equiv. : 101
Whitebalance : Auto
Metering Mode: center weight
Exposure : program (auto)
GPS Latitude : S 43d 47m 42.2312s
GPS Longitude: E 172d 22m 30.2887s
GPS Altitude : 105.20m
JPEG Quality : 100
Comment :
Cheers, Chris H.
