Heavenone
Flight distance : 3563 ft
hallmark007 Posted at 11-29 13:02
The 180 rule is used to show correct motion blur and that’s basically it , cinematic look you can put down to your talent to film, it has nothing to do with filters.
I think if you video in 2.7k which is half of 4K 25fps much better in 24fps which will come with new FW, if you then scale down to 1080p you should get some nice footage as seen on YT,I have not seen anyone using filters with MM but I have seen some really good footage .
Thanks for advices.Its true I saw before buying also a lot of good videos, but only in the USA,
so I live in germany and heard of a lot bader videos of europe than those who was made in USA.
Do not know the reason for it....
My mavic mini is a DoA, Problems with Video...shuttering, photos totaly unsharp,, lens has around lot of rest of glue, gimbal not fixed in the middle
so sometimes the picture makes a heavy jump downwords, MM moves at all ends of videos it do never stay in position if I stop in cine mode... and lots more, all proved by videos and photos.
As a DoP working for television I wanted to use the MM also for broadcast work if i travel abroad.
Now I wait for my exchange new MM and hope it will be OK.
