2 versions mavic mini hardware
12Next >
25124 56 2019-11-26
dji_MODDER
Flight distance : 73209 ft
check out these two pictures taken from 2 different Mavic Mini's
FCC version, buy in USA
CE version, buy in Europe
2019-11-26
InspektorGadjet
Flight distance : 439915 ft
Those are different sides of the PCB it would be interesting to see both sides in both versions.
2019-11-26
dji_MODDER
yes I see stby
2019-11-26
dji_MODDER
see red circle , fcc board
2019-11-26
dji_MODDER
CE board missing amplifier
2019-11-26
dji_MODDER
here the full FCC board, the chips are all covered with blue pasta
2019-11-26
dji_MODDER
2019-11-26
TruGreen
Flight distance : 621909 ft
this is wrong as well. in post #5 you have a totally different part circled... in this picture in Post #6 the little black square is covering what you have circled in post #5
2019-11-26
S-e-ven
Flight distance : 5922034 ft
Thailand
Isn't that front and back of ONE mainboard?
2019-11-26
InspektorGadjet
TruGreen Posted at 11-26 08:32
I agree you can clearly see the IC is also in CE version. Wrong part selected inside the red circle.
2019-11-26
ARTPiranha
Flight distance : 1115725 ft
Russia
Seems photos are wrongly marked! One with the missing chip (my guess amplifier) supposed to be CE!
2019-11-26
TruGreen
these would be a better comparison with both boards side by side. not seperate photos
2019-11-26
JodyB
Flight distance : 302536 ft
Despite the way these photo's are laid out and mis-circled areas, I can see what the OP is trying to get at. There is a hardware difference between FCC and CE boards in the Mavic Mini. originally a lot of us thought that there weren't any real hardware difference, but a software difference, I guess this kind of rules that out.
2019-11-26
Montfrooij
Flight distance : 2560453 ft
Keep them side by side in one picture!
2019-11-26
dji_MODDER
2019-11-27
Donsir_LTU
Flight distance : 1043940 ft
Lithuania
Can you see all the symbols on the missed chips? Chip from the right side is a wifi power amplifier from Skyworks Inc. I cant find a datasheet for sky746..... All needed part would cost a few euros I think...And you need good soldering skills/equipment to solder a lot of smd components (resistors, capacitors...)
2019-11-27
El Diabolico
You are showing 2 different sides of the motherboard... and yes, theres's an FCC version and a EU version.
2019-11-27
CemAygun
Flight distance : 810 ft
Turkey
Thanks a lot for the pictures! So now we know for sure that there are two different hardware versions, not just different firmwares...
2019-11-27
JodyB
Having all the missing hardware in place doesn't guarantee that what you're hoping for will work. Software/firmware could still be an issue. But if someone has a donor mini and is willing to try we may never know otherwise.
2019-11-27
Donsir_LTU
Lithuania
JodyB Posted at 11-27 06:53
Agree with you. I think there is more things to do than just add a missing hardware.
2019-11-27
markusd1984
JodyB Posted at 2019-11-27 06:53
Basically for new buyers it confirms one has to buy a FCC version in USA or via china if one wants to use the GPS hack to use the FCC mode for a more stable video connection (or utilize the full 4km distance).
Since modding an existing drone will certainly void the warranty one may just import an FCC drone.
2020-1-13
markusd1984
Donsir_LTU Posted at 2019-11-27 04:52
I think now it makes sense to me. If SKY is a booster for 5Ghz that would mean the two in red are the missing chips to provide the 2.4Ghz on FCC.
Therefore a CE drone while it has 5Ghz, without the booster it won't physically have the capability of the same performance of the FCC drone (for the full 4km distance/stronger connection).
Even if one manages to flash a CE kit with FCC to unlock the mode, it won't have the hardware in the drone to do it. (Modding it seems not worthwhile the hassle. Hopefully Aliexpress sellers will bring down the price to match/beat that of the official one from stores.)
2020-1-13
markusd1984
Your posts are confusing. In your previous pictures the FCC is missing the SKY chip and in your side by side comparison it's there. Did you mixed them up in the comparison picture, meaning the left is FCC and right is CE?
2020-1-13
markusd1984
markusd1984 Posted at 1-13 03:49
Correct?
2020-1-13
AntDX316
Flight distance : 3394731 ft
It's missing all the little components too.  If you guys just get a Mavic 2 Zoom it would squash all these problems.
2020-1-13
AntDX316
markusd1984 Posted at 1-13 03:59
[view_image]
If people are going to compare properly with everything off, at least clean off the thermal paste so we can compare the chip specs.  Do a close orthomosaic of the PCB in detail rather than have the images super blurry.
People need to know how to do the drag slider so we can compare CE vs FCC by dragging a vertical bar.
2020-1-13
HedgeTrimmer
Red circles are around two different spots.  Thus nothing missing.
2020-1-13
HedgeTrimmer
There are other missing components in FCC vs CE combined picture.
For example: Two small chips missing in upper left corner of CE version below top red circle.
4example
4example
2020-1-13
Alevpi
Flight distance : 43560 ft
Russia
I do not think, here is the instruction for the module on the Atheros AR1021X chip, I think the essence of the circuitry will be clear.
Atheros AR1021X
2020-1-13
markusd1984
Alevpi Posted at 1-13 04:59
Atheros AR1021X
Sorry, should have looked at the big chip first, being the Wifi controller AR1021X-CL3D
Ok the guys over here got much further with pictures and insights https://mavicpilots.com/threads/mavic-mini-a-look-inside.75814/page-3
djidroneservice provided some good close ups
Amplifier for FCC 5.8GHZ is the sky85746-11 which probably get's disabled during EU GPS coordinates (if detected prior take off).
2020-1-13
markusd1984
markusd1984 Posted at 1-13 07:36
no idea though why the pics are different to dji_MODDER if they both are supposed to be FCC, unless that's actually the CE version. Anyway, two good high res pictures to compare now.
2020-1-13
Alevpi
Russia
Need a full description of AR1021X-CL3D!
2020-1-13
fificap
Flight distance : 55531 ft
Hi,
Is there any differences at RC command hardware level, or only at Aircraft hardware level?
Thanks,
philippe
2020-1-13
Sigmo
Wouldn't the RC also need to be different between the two versions?  The FCC version of the RC would also need the extra power amp to be able to transmit with higher power to reach the Mini at greater distances, too.
Has anyone done a tear-down of the RCs so we can see and compare that side of things?
2020-1-13
BobWinNV
Flight distance : 284209 ft
AntDX316 Posted at 1-13 04:16
Or Mavic 2 Pro
2020-1-13
yamyamu
Turkey
This topic is getting more interesting, let me just send this comment and follow it
2020-1-13
AntDX316
But the lack of zoom
2020-1-13
BobWinNV
AntDX316 Posted at 1-13 17:51
I can zoom in post.
A 1 inch sensor and variable aperture  is more important to me.
2020-1-13
AntDX316
BobWinNV Posted at 1-13 18:24
I can zoom in post.
I prefer to zoom in while on-site so I can remain undetected or be at safer distance.  Zooming in post makes it not as sharp.  They don't market it as an inspection drone but it really is a great inspection drone.
2020-1-13
Sigmo
I can zoom in post.
I agree.   Having adjustable aperture would be fantastic.  And of course the larger sensor.  But I want both, so I retain the resolution of the sensor as I zoom.  ;)
But alas, a zoom lens to "feed" a 1" sensor would be big and heavy, so I'm sure we won't see that on a drone the size of a Mavic.  Gotta go with one of the larger platforms if you want it all, I'm afraid.
I like zoom lenses.  Despite what some people say, you cannot "zoom with your feet"  (or with your drone).  A zoom lens allows you to adjust both perspective AND composition.  You can't do that with a prime.  But as you say, you can always crop, and that does it, too.  You just give up some resolution, of course.
2020-1-13
12Next >
