InspektorGadjet
Flight distance : 439915 ft
nexus_redux Posted at 12-2 17:50
Had similar issue yesterday, did some research. Might be in context with colder temperature, if the mavic mini had no time to adopt to colder temperatures, coming from a warm room. Those 2 videos maybe explain and solve it:
describing the issue - example:
I can kind of confirm this, since I´ve been flying Ok with no shaky footage. It´s been like 12 degrees celsius, I´ve allways taken longer outside before I fly so drone had time to adapt to temperature change, today which it has been like 6 degrees, I took it from the warm house, to outside and took off pretty much in a couple of minutes... just to test the drone in dark light, and for the first time I´ve seen a little bit of shake...
Have to do more tests... |
