HedgeTrimmer
Cookster670 Posted at 12-1 14:50
So are you essentially saying that both phone wifi and dji wifi use the same frequencies AND channels so can therefore interfere with each other? Hope this helps.
WiFi is WiFi. There isn't separate channels designated for Phones, for Laptops, for Tablets, for Drones, etc.
Realize there are two ways WiFi devices run. Manual set to a specific channel. Or in Auto whereby device's system chooses which WiFi channel to use based on least amount of interference and availability.
Another issue comes into play, what modes of WiFi the device's hardware supports for communication.
As such, one can't say a smartphone is going to use same frequency the drone does for WiFi. If both smartphone and drone are in Auto, the two will choose different WiFi channels Whereas if both are set to Manual and both are set to same WiFi channel, the smartphone and drone are going to interfere with each other.
Realize it might be somebody else WiFi device that is set to Manual and using same WiFi channel your drone is Manual set to, which can cause interference. |
