DJI Support
Flight distance : 2408 ft
Overview:
- Date: 2019.12.02
- Air Unit Firmware: v01.00.02.00
- Goggles Firmware: v01.00.02.00
- Remote Controller Firmware: v01.00.02.00
- DJI Assistant 2 (DJI FPV Series): v2.0.0
What's New
- Added support for recording AV IN analog video transmission. Reset the goggles to the default settings to ensure that the functions in the AV IN interface can be used normally.
- Fixed issue: display issues appeared in AV IN analog video transmission.
- Optimized AV IN analog video transmission to improve real-time performance.
- Added ability to customize the on-screen display information for the goggles, which supports 24 OSD items of information items in total. (To display GPS information, enable the UART port which is connected to the GPS in Betaflight software)
- Added ability to adjust frame rate and bit rate according to distance and channel bandwidth when the transmission distance is more than 1 km.
- Added support to connect the remote controller via USB cable to PC to play the simulator. (The simulator software needs to support USB HID input)
- After activating the goggles, it will enter Channel 1 by default.
- Optimized UI menu of PID Tuning.
- Optimized microSD card error type. “SD card full” appears when the microSD card is full during recording.
- Fixed issue: playback speed was slow when playing 120fps video on the goggles.
Notes
- Restart the air unit, goggles, and remote controller once the update is complete.
- Make sure that the firmware of the air unit, the goggles and the remote controller are in the same version. Check the firmware version in Setting, Device Info, and then Device Info on goggles.
- If the firmware update fails, restart the device and DJI Assistant 2 (DJI FPV Series), and try updating again.
- Restart the air unit after setting the protocol between the air unit and flight controller.
