DJI Digital FPV System Release Notes (12/2/2019)
12
7706 73 2019-12-2
djiuser_6fZeahjPliQV
Poland
fans57e7a0ca Posted at 12-3 15:39
Awesome! A more complete OSD was one of the two functions I missed with the DJI FPV System.
The second function I'd like to see implemented is live audio transmission from the quad to the goggles using an earbud. The DJI Air Unit can record audio to the MicroSD card, so there is a microphone in the Air Unit. The Goggles have a headphone jack. Can DJI make them work together to transmit audio along with video?
oh yes .... I also miss sound and I was also wondering if it can be sent along with the video ...
2019-12-5
Snyder7
Brazil
Kevin_B Posted at 12-5 04:47
Snyder7, one of the available OSD elements is RSSI.   It's showing in my goggles.  I think the bars it shows by default is the Video link RSSI/quality.  The RSSI OSD element would be the Control link quality?   Someone please correct me if I'm wrong?
One other item I missed in my original post was the "Warnings" element.  That's an important one to add!    If adding too many has some effect on latency, they could leave out the PID settings.   You don't need that on the screen all the time.  You'll see them once you land and go into the menu to make the tuning changes anyway.   Also Main Voltage could be dropped from the 24 since that is already displayed in the lower right as a default item you can't change.
Hi Kevin, ok in my google show RSSI information too but is not correct, here shows 11 or 10 for any distance
2019-12-5
Kevin_B
Snyder7 Posted at 12-5 08:30
I have one quad that is a fully functioning analog quad with R9 for control, and analog (Tramp) and DJI for video.   On that one, I'm using the analog RSSI signal from the R9 receiver to the FC, and the RSSI shows up correctly in both my fatshark and DJI goggles.
On this one, it's clear the bars at the bottom left of the DJI goggles react to goggle antenna position (video link), while the RSSI element reacts to the placement of the R9 transmitter (control link).
I'm also in the middle of building a DJI-only quad.  On that one, if I turn on the RSSI_ADC in the BF Configuration tab, the RSSI in the  BF Setup tab (and in the DJI goggles if the air unit is powered up) reads 8-11 regardless of whether the Air Unit is powered up by a battery pack or not.  So that is not the way to go.  I also checked to see if there was an Aux channel in the BF Receiver tab that looked like it might be carrying RSSI.   No go there either.    So I'm still looking for a way to drive the BF RSSI from the Air Unit.
Perhaps the DJI system is designed that the control link will always outperform the video link?   Maybe there isn't a way to get RSSI from the air unit and if your picture and latency is good enough to keep flying, you don't need to worry about an RSSI number???  If the picture is getting blocky, your latency is over 50 and your bandwidth is under 5....... it's time to turn around?
I'll keep digging and post here if I find an answer on driving the RSSI with a value from the air unit.
KevinB
2019-12-5
r650
Sweden
Any news about sound?
2019-12-6
morbius
Would it be possible to develop a linux application and a process to download the update to a computer to load separately?
2019-12-6
fansa390d7b5
Hi guys ! Does it need to upgrade flight controller to V4.1?
2019-12-6
djiuser_V5X93qToJc6V
Hi all,
Is anyone else having trouble changing their pids after the new firmware update? Before the update I could change all aspects of the pids, albeit with teying to add 5 points then it automatically taking one or two down but I could change it. Now it doesn't matter how much a move it,  it just jumps back to the original position. Also changing pid profiles is a bit hit and miss. It beeps nothing changes, I exit the pod settings then re-enter and the number jumps up and down. As if its cued the commands? Does this sound familiar to anyone else? Thanks for any help and happy flying!!
2019-12-7
Bol2riz
djiuser_V5X93qToJc6V Posted at 12-7 09:22
Hi all,
Changing PID works for me with the latest update.
Best
2019-12-9
shambler
Austria
Hi all,
I had the problem as well yesterday.
2019-12-9
Zeqons
India
The marketing strategy plays a very important role in transforming a company into a successful brand. There has been a great demand in terms of digital marketing platforms in recent years, but now with the advent of digital marketing services, the problem has disappeared as many companies opt for digital marketing to reach their audience. A professional and reputable digital marketing company assumes responsibility for marketing and advertising your company's products and services so you can rest in peace. A new company needs to use these services to achieve a high return on investment. No other service provides the same results like digital marketing because only these services promise to deliver guaranteed results in a few months.
Common services offered
Most services include social media marketing, email marketing, digital advertising, content marketing, search engine optimization, influencer marketing, digital marketing, and rate optimization. Conversion These services are very useful to grow and expand your business. These services are very useful in today's business compared to conventional marketing media. However, these services are very useful for promoting business.
Tips for hiring the most compatible company
· To hire the best, do detailed research on your familiarity, practices, marketing team, past projects and more. By doing so, you can reach a conclusion about hiring or not.
· Always check the reputation of the company, as there are many digital marketing campaigns scattered on the Internet. Reputable companies would have experienced challenges and difficulties in serving their customers. You must choose highly experienced and reputable online services for your business needs.
· Compare the cost with others to finish the best service at a reasonable price.
· Know your tools and techniques so you can get digital marketing according to the latest trends.
Advantage
· High-quality service: choosing a competent company will guarantee high-quality service. A professional company will develop and implement effective marketing techniques for your business. Generally, they have well-trained and qualified professionals who work with total commitment and dedication to successful marketing strategies according to the requirements of the clients and their businesses.
· Reach the target audience: by incorporating the right strategies for your business, you will surely benefit from a wider range of potential and potential customers. No business can succeed without a target audience, so it is essential to create marketing based on your needs.
Profitable: outsourcing your company's marketing services to a profitable business will reduce your burden and save money by employing a team of internal marketing specialists. They usually have specialists who have several years of experience in the field of marketing. However, they will provide you with a detailed plan for your marketing costs in advance so you can do everything in class without worrying about money.
An expert in digital marketing. I am looking for information on the latest market trends and I am making the necessary updates in this regard. If you want to get more information about the services of a digital marketing company in India, you can follow me and read articles on related topics.
Best Digital Marketing Company Noida | Digital Marketing Agency Noida
2019-12-9
chaos523
Hi DJI - I would love to use the DJI FPV System on my fixed wings - my fixed wings do not have an FC - is it possible to set the transmission power to 700mw without having an FC connected to the Air-Unit (i read that the Poweroutput is limited to 25mw unless the unit gets a signal that the motors (of a quad) are spinning or it is armed) - it would be great to have the possibility to set the air-unit to 700mw and really get it just with connected power - is this possible?!
2019-12-9
fredbotton75
Flight distance : 488832 ft
@chaos523 : Yes you can. Channels, emitting power, etc. are not linked to the FC. So the only required thing is to power up the FPV Air Unit (red and black cables), you control emitting power from goggles. I'm running a standalone FPV Air Unit on a RC car with no FC whatsoever, just wired to a 3S power source. Automatic control of emitting power as well as auto recording only work when FPV Air Unit is properly wired to an FC.
2019-12-10
fredbotton75
With v01.00.02.00 on DJI Goggles, I'm still unable to get an analogic feed, screen remains black except for recording symbol.
I have tried various combinations of pal & ntsc cameras, various vtx, none of them worked.
What's strange is that:
- When switching on the feed on vrx, I can see the DJI logo come then go.
- Analogic recording on DJI Goggles works fine even though screen is black (see screenshot of recorded video below)
- Analogic display comes back with Goggles downgraded to previous firmware.
Looking for some clues!
2019-12-10
djiuser_bR96HjHcRcS2
Same here, analog broken with black screen. @DJI show some customer obsession and at least answer here and give us an update.
2019-12-10
silpheedx
Flight distance : 11936 ft
"Added support for recording AV IN analog video transmission"
HOLY!  YEEESS!! Thank you so so so much!
2019-12-10
RyanHayudini
Philippines
singlag Posted at 12-2 10:06
AV-in show blackscreen after update, but DVR video is fine
after downgrade the firmware, AV-in resume normal, but still show blackscreen after reflash to Goggles Firmware: v01.00.02.00
all my analog camera are 16:9, both NTSC/PAL are same result on 3 different VTX
I just update mine to v1.00.02 and the same happened. Refresh the firmware and still the same.
AV input is a blank screen but can record dvr.
2019-12-11
fredbotton75
I've found a workaround for that black screen bug, changing display size to 70 % in Display/Display/Zoom Out menu, and then switching to A/V In shows the analog feed! It is possible to get back to 100 % (which actually does not fill the whole screen), analog feed stays, even after goggles power down and up again.
2019-12-11
mosh-fpv
Please look into supporting the Eagle Vector FPV system OSD. I use this system for my fixed wings and quads that need RTH capability. I find the feature set and ease of use to be MUCH better than iNav and this is a very popular system. There is a telemetry out from the system that can be used for OSD on the DJI FPV.
2019-12-11
RyanHayudini
Philippines
fredbotton75 Posted at 12-11 07:59
[view_image]
Thanks for this, I will try this later. DJI should atleast respond to this concern.
2019-12-11
djiuser_ItiFTPvtiGBZ
Poland
Same problem here. DVR records and plays back the footage, no live view though.
2019-12-13
Poland
djiuser_ItiFTPvtiGBZ Posted at 12-13 08:39
"Reset All" helped in my case.
You should see the "blue screen" when no av source is connected instead of the black screen.
2019-12-13
Tutuapapps
Sri Lanka
Thanks for the information.
Tutuapp
2019-12-14
fans96f2d307
Flight distance : 15873 ft
Switzerland
Hello. I have much trouble with the new Firmware 01.00.2 (OSD):
I came from v01.00.1 and had no issues with the analog video Input. (Bluescreen when no AV Cable detected, and Videofeed from the Dockking (furiousFPV) if AV connected)
As soon as i upgrade to the new Firmware, i just get a black screen at AV-Input.
I restarted the goggles after the update. And also made a Factory Reset before checking AV Input.
When i downgrade to the older Firmware, the Videofeed on AV Input is back.
I also tried different AV-Input Cables and different modules in the dockking.
As soon as i update to the newest firmware, the videofeed is gone and blackscreen.
AV Cables are fine. I double checked everything and tried to down / upgrade serval times.
Av Input from the Modules works on my HDO goggles.
How can this be possible? Is there already a fix?
I spoke with the seller of the goggles, he told me to first check at the Forum.
Thanks for the help
2019-12-15
fans96f2d307
Switzerland
Thanks for the help
2019-12-15
GMD
Portugal
Hi all,
I have the same problem, but I can change very slowly, it is not practical. Buggy firmware .
2019-12-15
fredbotton75
fans96f2d307 Posted at 12-15 08:56
See msg #57 in this thread...
2019-12-17
fans04b60dc6
Flight distance : 627940 ft
Is it possible to switch to stick mode 4 on the transmitter? I have the mode 2 version but would like my aileron and rudder channels swapped.
2019-12-18
Bol2riz
fans04b60dc6 Posted at 12-18 01:26
Would love to have that kind of extra settings in the radio too.
At the moment I think you can do that via Betaflight (if you use it) in the radio screen, if I'm right it's the AETR drop down menu that changes the order to your needs.
Best
2019-12-18
grymlock73
[view_image]
You sir, are a god among men. =)  Thanks for the fix!  I had to zoom out to 50% to get mine to register but after the AV-IN feed was successful, I backed out and reset it to 100% with no issues.
2019-12-18
WAVER_FPV
Flight distance : 173120 ft
Hashemite Kingdom of Jordan
The air unit recording freeze and stopped like after 1-2 minutes!
what is happening? but on the goggle everything is okay!
2019-12-23
JchgMad
Flight distance : 3238 ft
WAVER_FPV Posted at 12-23 13:15
try with SD U3
2019-12-24
cusglider
Flight distance : 4025801 ft
Lebanon
Reading the Ah used
works till around 600 mAh being used. Then frequently the display freezes for even more than 30 secs or a minute along with the display of the actual use.
Mostly after disarming the data updates to the latest. I would be happy to see this bug being addressed.
I also frequently get a message inflight like "you now are on the public channel" although no inflight change of channels happened.
2019-12-26
WAVER_FPV
cusglider Posted at 12-26 12:39
Reading the Ah used
@JchgMad
will try the u3 and see! thanks
@cusglider
I think this is a common issue with the new dji update.. many are having the same and waiting for a fix from DJI.
2019-12-28
rocketsarefast
AUDIO !!! please make live audio work. The air unit has a microphone and goggles have a headphone jack. I have never flown without audio. It is really hard to fly without audio. I was devastated after buying the goggles to discover that it does not have live audio. I am considering returning them, even though the video feed is amazing.
1-13 20:52
12
