Paul Atkin
Flight distance : 36962 ft
DJI Paladin Posted at 12-3 10:42
Hi. Thank you for reaching out to DJI Forum. For the "Max Power Load Reached" message. There are two scenarios that would trigger this prompt. First, the aircraft might be flying with full power under the sport mode against the wind direction. Second, the aircraft might be flying with full power with propeller guards installed. Rest assured, this message is considered as normal and we will optimize this application prompt in the near future. For extracting the flight records. Please download the DJI Assistant 2 at this link ( https://www.dji.com/mavic-mini/downloads ) after installing the said application. Turn on and connect the drone to the computer. Once the DJI Assistant 2 recognizes the drone, kindly please choose " Log Export " then click " Save to local ". These are the steps for extracting the Flight Controller Data of the said drone. If you have further inquiry please feel free to post it here at DJI Forum. We are here to help. Thank you.
for what it matters - i just had same "Max Power Load Reached" message while in S mode, no cage on props, simply giving max throttle to get to 40-50m altitude, with almost no wind at all. all i could see in log was the OSD.isNotEnoughForce signal flipping from FALSE to TRUE, why - not clear. nothing obvious indicates any overload.
it also gave a wind warning later, but, by sound of props it did not look like it was strugglig with wind at all.
