No live feed since 3.08 Upgrade
2260 12 2014-11-16
DaveM
Flight distance : 23035 ft
For once I waited a while after a firware release to upgrade my Phantom Vision Plus
Sadly this has resulted in the live feed no longer working, but telemetry info, take pics
start video is all working OK.
Using a Mac I used assistant 3.6 and with the exeption of the battery upgrade, done
them all including the latest iOS app
Phantom 2 Vision+ Autopilot System - V3.08
Phantom 2 Vision+ Central Board - V1.0.2.7
3-axis Gimbal - V1.0.0.6
Mac Assistant Software - V3.6
iOS App - V1.0.43
Tried using the V3.4 assistant and upgrading again, but no luck
Deleted and re-installed the iOS app
Re bound the Wi-Fi extender
Tried my iPad and also Android on a Galaxy tab
Checked all cable connections
Lowered preview quality to lowest
I had no issues doing the upgrades, all went smoothly without any errors or problems
Spoke to my dealer who have been checking and waiting for an answer from DJI
(Still waiting for 6 days)
Any help appreciated
Possible w-Fi Transmission Module perhaps ?, although I have never experienced any
problems or dropouts with the video feed before the upgrade
IPhone 6 plus Feed
IPhone 6 plus Feed
2014-11-16
DJI-擎天柱
China
Please send a mail to support@dji.com.
2014-11-17
DaveM
Many thanks, I will do that
2014-11-17
maionaze
Flight distance : 1043678 ft
DaveM Posted at 2014-11-17 19:41
I had this problem also. I say had because I think it went away. After having it, I discharged my batteries and then recharged them. The problem hasn't returned after 4 flights since I did this. If DJI has a different response, please share because like I said, it "seemed" to be fixed. But I am not 100% sure of it.
2014-11-17
DJI-DingC
China
Have you try re-connect the gimbal? I would suspect this is a hardware connection issue.
2014-11-17
DaveM
DJI-DingC Posted at 2014-11-17 23:23
Yes, I have just disconnected and removed the gimbal, all cable connections
were OK, but I removed them and re-plugged in again, sadly exactly the
same still NO Live View
2014-11-17
well69
You're not alone.  Do a search for black screen - many users have this problem after the last update.
2014-11-21
DaveM
All fixed now
Replaced the Wi-Fi transmission module
2014-11-21
jbedard
I have the exact same setup and the exact same problem?   Any luck with a solution?
Thank you
2014-12-26
ciprianboboc
Have you tried to apply all available updates?
I've noticed you have version 1.0.2.7 for CB, while version 1.0.2.10 is available right now...
Also, make sure you restart everything (including remove the app from the phone memory).
2014-12-26
jbedard
DaveM Posted at 2014-11-22 04:27
All fixed now
How did you replace the wifi transmission module?  Where did you buy it?  Thank you.
2014-12-27
johnjohnsoniii
I am worried that I may have a similar problem. Same symptoms...
2015-1-7
tobinrichard
All fixed now
Hi Dave,
I have the same issue as you and I replaced the Wifi Module and it still doesnt work..
Any ideas
2015-6-24
