Image transmission stopped
8741 14 2019-12-4
djiuser_gmXud1ZTqntD
Japan
I use the DJI FPV system T motor F4 HD FC. I turn everything on as far as your remote control is connected to the FC, but what starts up with the goggles also disconnects the remote control. As soon as I turn off the goggles, the remote control is reconnected.
I returned the DJI FPV Fly More Combo (Mode 2) FPV Drone Racing to Amazon.com and purchased and used a new item of the exact same type. In addition, I also purchased an AirUnit. I also got an T-Motor F55A PRO II 55A ESC&F4 HD for DJI stack and now I have three. I bought new batteries too. I tried two versions of each firmware. Is there anything else I can try? I have no idea what to do anymore. I'm sorry for bothering you during your busy time. Thank you for your cooperation.
https://youtu.be/AUkg8Pq_S0I
2019-12-4
fans1dbb9bb9
Flight distance : 342054 ft
Hello, I'm having the same problem I get an error: image transmission stopped. I'm not sure why i get this message. Has anyone found out why the Air unit is having trouble? I've updated to the latest firmware and still get the same error.
2019-12-26
Poci
Flight distance : 1372057 ft
Norway
Hi guys! I have problem with image from camera
What do you thing about this?
2020-2-1
jnamongmail.com
Flight distance : 233012 ft
Same issue. Has anyone resolved this? Air Unit green and ready to link but can’t get goggles into bind mode.
2020-2-4
Japan
That's already been resolved!!!!!!!!!!! YOU SHOULD USE USA VPN FOR UPDATE AIR UNIT !!!!! I AM FROM JAPAN
2020-2-25
djiuser_3hySjHfO054R
Japan
djiuser_gmXud1ZTqntD Posted at 2-25 05:56
対処法を教えてください 私も日本人です
2020-5-7
djiuser_ArgbF8VgWyAq
The issue has not been resolved I have the same issue and I’ve updated, backdated and re-updated to the most recent firmware. Is there any way to fix this when out flying?
2020-6-4
FPV-King
Exactly the same here!
I get an error: image transmission stopped, just after upgrading the firmware
This is my new brand new air unit, the other air unit do not have this problem
Is there a problem with activating the unit before the first use?
2020-6-4
Sam
This happen to me a few times
2020-6-4
Thomas V
@ jnamongmail.com. What are you experiencing when you click the bind button on the goggles? A single beep, or the expected continuous one?
2020-6-5
FPV-King
Thomas V Posted at 6-5 07:01
Hi Thomas
Sorry if i misunderstand you, but i am not ware of a bind button on the goggles.
The transmitter bind normallay automatisch af a few seconds and turns green, but now stays red. Also the goggles do not receive a response from the airunit.
2020-6-6
g.arturas
Flight distance : 660138 ft
i press button on air unit first and hold after on goggles and hold, that issue diapered to me and all works
2020-6-25
Thomas V
FPV-King Posted at 6-6 04:04
Hi Thomas
You can find the bind button as indicated on pages 21, 22, 23 under the subject "Linking" in the DJI Digital FPV System User Manual 2019.07 v1.0
https://dl.djicdn.com/downloads/DJI_Digital_FPV_System/20190731/DJI_Digital_FPV_System_User_Manual_EN.pdf
2020-6-30
burnsideboogz
jnamongmail.com Posted at 2020-2-4 20:26
Same issue. Has anyone resolved this? Air Unit green and ready to link but can’t get goggles into bind mode.[Image]
Hey can someone assist me with my goggles v2
2022-8-22
djiuser_sRxPM5dgltVY
Puerto Rico
fans1dbb9bb9 Posted at 2019-12-26 07:24
Hello, I'm having the same problem I get an error: image transmission stopped. I'm not sure why i get this message. Has anyone found out why the Air unit is having trouble? I've updated to the latest firmware and still get the same error. [view_image]
Hi, what you do to resolves this
2023-8-26
