ISSUE - DJI Digital FPV System Release Notes (12/2/2019)
1915 5 2019-12-4
om.antonFPV
Indonesia
I just update my airunit & goggles with the latest firmware (v01.00.02.00), but the osd seems not working at all (battery voltage also missing), i used all recommended parts from dji website. I also change custom osd at goggle to "On". any help would be greatly appreciated.
FC & ESC : Tmotor F55AproⅡ +F4 HD STACK
Betaflight : 4.1
2019-12-4
michi.fpv
I have the same FC, ESC and Betaflight 4.1 and it works perfect. I see you have activated in the osd tab some values ​​that do not work yet. But the main problem is that your voltmeter also shows nothing. Did that go before the update? If not, your RX / TX is reversed. You also did not select GPS as Sensor in the UART tap.
2019-12-5
Kryml Munsta
Flight distance : 185262 ft
You need to activate MSP for the UART thats connected to the DJI FPV System
2019-12-5
TechnoCore
Kryml Munsta Posted at 12-5 10:54
For sure this ^
You can see in your ports configuration that you only have the 1 MSP, you should have a 2nd MSP for the DJI FPV system or you won't get any of the integration, even before this recent OSD update.
2019-12-7
myhrmans
Flight distance : 19767 ft
Japan
As prevouis people has sad. Active MSP on UART1 most likley.
2019-12-22
rabbitfilmsfpv
Brazil
hey! same problem here.
i cant active msp on the same UART . anyone can help?
2020-4-11
