Possibility to access through internet (WAN / NAT)
[ilkeraktuna]
Flight distance : 292 ft
Turkey
Is it possible to access Robomaster from an outside network using direct IP address and port information ?
I really would like to access it when I am not at home using port mapping on my router.
Is this possible ?
2019-12-5
BGA
No. It uses non-routable broadcast UDP packets for several things. You could potentially get it to work by setting up a VPN tunnel, but latency will most likely not be great.
2019-12-5
[ilkeraktuna]
Turkey
ok , I understand that the app finds the device using broadcast packets. but them my question is:
does it offer a ad-hoc network to connect or can we connect it to our home wifi ?
2019-12-5
BGA
[ilkeraktuna] Posted at 12-5 12:05
Both. But you can not battle other S1s is ad-hoc mode, you need a router. You can control a single S1 in ad-hoc mode.
2019-12-5
djiuser_uguut1RtN1Hl
Brazil
oi boa noite quem do forum pode me ajudar eu troquei o guimbal e os flat do meu drone mini e ele ta morto dizem que e preciso de softwar especial pra calibrar o guimbal isto e verdade se for como consigo o softwarw pra calibrar o meu pra voltar a funcionar obrigado
1-30 14:15
