DJI Thor
Flight distance : 13602 ft
StubbornSwiss Posted at 12-5 18:03
As a follow up, still using Assistant 2, I downgraded the RC firmware, and re-updated it, and for whatever reason the beeping stopped.
I also discovered from a Google search, that the said beeping might be an indication that the RC needs to be calibrated. So I went ahead and did this.
Hi there, just for your reference, the controller may make beeping sound in the following conditions:
1. The controller has less than 10% power, please charge the controller;
2. The sticks/dials are not in the central position, please calibrate the RC;
3. An error existed on the controller, please try to refresh the firmware.
In your case, as the beeping sound stops after calibration, it could be the position of the sticks. Please don't worry. Keep us updated if the issue persists.
