DJI Stephen
Hello and good day Salex123. I am sorry for the trouble this has caused. With regards to the RTH function of the DJI Mavic Mini. Before the flight, go to “Safety” and set the RTH altitude higher than that of the tallest building in the surrounding area. You can set the RTH altitude from 20 m to the max flight altitude. When the Home Point is recorded and the distance between the aircraft and Home Point is more than 20 meters, you can tap the icon shown on the left of DJI Fly to choose to land or initiate RTH. Press and hold the RTH button on DJI Fly, or press and hold the RTH button on the top left of the remote controller to initiate RTH. The remote controller will make beeping sounds(after the RTH triggered,can short press RTH button to stop the beeping sounds, the return will stop too.). When the GPS signal is strong, the aircraft will return to home.
Note: If the GPS signal is weak, the aircraft will hover ( if the GPS signal does not get stronger, the aircraft will hover for three seconds to prevent itself from drifting because of the poor GPS signal ), and then the aircraft will land. If the distance between the aircraft and Home Point is less than 20 meters, after users press the icon on the left of DJI Fly, only the landing option is available. Thank you and have a safe flight always. |
