Mavic Mini reset to factory settings guide pls?
36259 13 2019-12-7
djiuser_lIxAzs3oT833
Flight distance : 10433 ft
Singapore
I intend to sell away my mavic mini therefore i cant seem to find that restore back to factory settings in the Dji Assistant 2 app under Firmware update. As far as i understand it does work for the other Mavic series.. anyone able to help me out pls??
2019-12-7
DowntownRDB
Flight distance : 1722 ft
Quick tutorial here:  https://www.hardreset.info/devices/dji/dji-mavic-mini/
UPDATED:  As stated in Post 3 it confirms that this tutorial is incorrect in that it is saying to use Assistant 2 for Phantom vice Assistant 2 for Mini.  Assistant 2 for Phantom does have a hard reset tab but unfortunately Assistant for Mavic does not have a reset tab.
I sent an email to DJI Support on how to hard reset and they have not replied yet.  Will update post when/if I hear back.
2019-12-7
Afk_81
Singapore
this was method i tried bro, its actually for mavic pro not mini
2019-12-7
JodyB
Flight distance : 283478 ft
Looks like Mavic mini to me. I have no reason to reset mine so I haven’t tried either. Hopefully if this guide is wrong you might figure it out and give us the correct way to do it should someone else need to.
2019-12-7
blakamin
Flight distance : 68458 ft
What settings do you think you are you going to restore?
The app saves everything.
2019-12-7
blakamin
I wasn't able to edit in time..
The app keeps all the data. If you reset through that, about the only thing the drone will remember is the last home point and RTH height.
Remember, the Mini has no onboard storage like other drones.
2019-12-7
coyote20
Austria
blakamin Posted at 12-7 22:34
i don't think so. because i had uninstall the app, deleted all data from smartphone and after a new install, the app know my copters name, and some other informations.
so the copter, i think, has a small storage(chip) inside.
2019-12-28
the1shark
Flight distance : 43156 ft
Israel
coyote20 Posted at 12-28 10:57
No, this data is stored on Google servers if you are using Android or your iCloud account, if you are using IOS device.
2019-12-28
Molto33
Flight distance : 22228 ft
DowntownRDB Posted at 2019-12-7 12:22
Any news about it ?
I would like to reset mine about the yaw delay controls which isn't present in the factory firmware.
2020-1-17
DowntownRDB
Molto33 Posted at 1-17 05:43
Any news about it ?
DJI finally replied and said that it is not possible to hard reset MM to factory settings.
2020-1-17
Espace2020
Flight distance : 11119 ft
Switzerland
It is the future customer of the drone that if I am returning, who will not be happy ... seeing for example that the view counter is at 52 .
2020-2-29
djiuser_bgT0UIZpwb7G
Pakistan
My Mvic Mini is strucked. It is not powering on. Can anyone help please? Last time, after a successful flight, it was not powering off, then I removed the battery. After that, it is not powering on.
2020-7-10
Skydiver021
Serbia
What's happend when reflash with the same firmware version with Dji Assistant 2 app, keep settings or set it to default?
2020-7-11
djiuser_bB4K4FAe9TVn
Indonesia
I was format my sd card and somehow my footage became poor resolution, soni think i should reset my mavi mini?
2020-7-22
