PhantomAndy
Flight distance : 1156378 ft
I've had my Mavic Mini for just under a month now (FMC) and yesterday when I plugged in the charging hub to get ready for today's flights, the hub lit up and showed batter status, but then all lights went off. I've only cycled the batteries a few times (always using the hub). When I unplugged the charging cable from the hub, it lit again, then when out (normal). Plugged the USB micro cable back in, and it lit and went off, then on, then off.
It's acting like the micro USB port has a loose connection inside or something. Anyone else experienced this? Possible that I'm going to have to send in for service which is a bummer.
To pre-answer some questions: Using the DJI charging adapter, and DJI supplied charging cable. I've only used these cables and adapter adapter that shipped with the original fly more combo in conjunction with the charging hub.
Anyone else seen similar?
