Mark The Droner
Flight distance : 2917 ft
Manu P4P Paris Posted at 12-9 10:53
yes! I tried the battery with 42% (just 1 meter) to check the cells status..then now it's reached 8% and I'm charging the battery.. tomorrow I'm gonna try it from 100% as it has to be done, I know it
For the record, the manual does not say to discharge the battery until "it's reached 8%." The manual says to discharge "...until there is less than 8% of power left...", which means at least 7%, and I've seen 3% argued as a good target. And from what I've read, it matters. There is something triggered when one brings the battery below 8% which isn't triggered when one brings the battery only to 8%. I read this years ago in a P2 thread from a guy who did extensive testing on this.
Nonetheless, my experience and the experience of a lot of other guys is that discharging a battery to very low levels eats maximum mAh, which is to say, the battery won't stay on as long in later flights. This can be confirmed by studying the battery data in your logs before and after. Deep discharging repeatedly will give the battery an early death. That's my experience.
But due to differing opinions and also the strange and obvious contradictions in the manual, you'd be happier if you did your own research.
Good luck |
