I recently bought a Mavic 2 Zoom. It works fine but when I put it into ActiveTrack / Trace it won't circle around the subject the way it's supposed to.
I moved the slider bar like I'm supposed to but...no go.
Hi, thank you for reaching out and we do apologize for the inconvenience. Can you please try to perform the ActiveTrack in an open area wherein there is no possible obstacles that might interrupt the said feature. Also, can you please send us a video showing the problem for us to help you further. Please keep us posted. Thank you!
DJI Gamora Posted at 12-12 09:27
This was a wide open field. No obstacles. Really not much to video...the slider moves but pops right back to center (0 point) when I let it go instead of staying like it should. Drone doesn't move.
djiuser_9PkfhzP2w3Ie Posted at 12-12 19:33
Hi, thank you for the additional information. Can you please try to sync all of your flight records then try to uninstall and reinstall the application to see if the problem persists? After that, you may try to relink the RC to Aircraft as well for us to make sure that the connectivity of both devices is there. You may refer to the tutorial below. Please let us know the update of the said issue. Thank you for your support!
DJI Gamora Posted at 12-13 16:07
https://www.youtube.com/watch?v=HUVwvfIdnXA
How do I 'sync all my flight records'? I don't even know what this means.
And when you say 'uninstall/reinstall the application' are you referring to the DJI GO application I just recently installed on my Android?
djiuser_9PkfhzP2w3Ie Posted at 12-15 16:53
Also, my phone/controller connects/commands the drone perfectly with the exception of the Activetrack orbit function...are you suggesting that there could be a connectivity issue for a specific feature?
Hi, For you to sync your flight records: 1. Launch the DJI GO 4 app > Tap the three bars icon in the upper-right corner > Click “Flight Records” > 4. Click the cloud icon in the upper-right corner > Select “All” and click “Start Synchronization” > Click “Complete”. Also, We do have the tutorial on youtube for the DJI Go app syncing flight records it is more likely the same with the DJI Go 4 application. You can try the troubleshooting steps that I have provided to you and please let us know if the issue persists. Thank you!
HI, I have seen my Mavic 2 zoom do this too, I think i raized the altitude and the slider moved and locked at a position in the arc and the drone started to circle me as I Rode my bike down a hill.
TVOD Posted at 12-21 18:39
Really? So you just raised your altitude and it worked? I'll definitely try this, thanks!
THANKS! Because of you my Zoom now works like a champ. Your suggestion to increase my Zoom's altitude in order to get it to orbit in Trace mode was spot on. You're a God
