Manes F
Dear All,
First of all, excuse me if I am doing a silly question.
I am working on a project for automatic geo-referencing of hot spots in solar farms. I have completely configured a M210-RTK-V2 with Z30 and XT, we have made all sort of tests in manual flight, everything goes perfect but now we have found a problem.
We need to flight different types of pre-programmed missions: grid missions to obtain an orthomosaic of the plant and waypoint missions. When trying to select the camera type in the menu only the following options are available:
Phantom IV
Phantom 4 Pro
Phantom 4 Pro V2.0
Phantom 4 Advanced
X7 (24 mm)
X7 (35 mm)
Mavic 2 Enterprise Zoom
Custom camera
No option for XT2 or Z30 exist
It is true that it seems to be possible to define my own custom camera, name it XT2 or whatever I want. However, the problem is the following: if I do things this way and I want to use XT2 it is obviously impossible to assign data from two sources. I mean if I define the camera using the specs of the RGB camera of XT2 I understand it will not work properly for the thermal and vice-versa. Moreover, size of the thermal sensor is unknow. I think I calculate it from the FOV lens and resolution, but nevertheless I still go on without knowing or even understanding why the only compatible cameras with M210-RTK V2 do not appear in the menu.
By the way, I have to transmitters and two Cristalsky. Is it me or the táctil LCD when running all the software becomes slow and really annoying and one has to press with his/her fingers a dozen times to define areas and so on 8-).
I would be very grateful if you were so kind as to give me any suggestions.
Best regards and Happy XMas from the north of Spain!
Manés
