Alevpi
Flight distance : 43560 ft
Russia
Source data: 3 batteries and support charging one QuickChange 2.0 battery in the Mavic Mini itself.
The battery charging Cup should be:
1. For two batteries (To charge the thirds there is the drone itself).
2. With two connectors for charging the Cup with the logic of operation: when you connect one charging cable, two batteries are charged in series, when you connect two charging cables, it is charged in parallel.
3. Supported QC 2.0 charging (as implemented in the drone itself).
4. When using the beaker as a power recoil device, there should also be support for QC 2.0
