DanGro
Just to clearify the last reply: 3 Volts is not safe for a Lipo, it's the absolute minimum where you start damaging it. 3.2 Volts is a safe absolute minimum. 3.5 Volts is safe.
And the probable reason why your multimeter shows a higher voltage is because it's not under load. The voltage of a Lipo drops under load, which is why you shouldn't really go under 3.5 Volts, which should read about 3.2 - 3.4 Volts depending on the current you draw from it.
