DJI Stephen
Hello and good day Randy. Thank you for reaching out and for the inquiry. It is recommended to cache the map with Internet before flight. At home, with WiFi enabled, go into the DJI Go application, and be sure cache Maps. Please have your drone turned on, when you do this process. Now open the DJI Go application and bring up Map View. Once you have everything running, scroll to your proposed flying area. Zoom in, to the flight area, and scroll the map around, well beyond your planned flight zone. After doing these process and once you turn everything off, the proper map should be available on the DJI Go application. Thank you. |
