Manually catching the MM and powering down
1206 12 2019-12-20
telecam
Flight distance : 1540384 ft
Catching the MM is pretty easy as long as you position it at a good height, close enough and are quick to grab it.  Then I found out in an online video that once you have a good grasp at it, flipping it upside down kills the motors instantly which is much quicker and more convenient that powering off from the remote.  Is there any downside in doing so?
2019-12-20
JodyB
Flight distance : 302536 ft
Other than possibly catching a finger or hitting it against something, there are a few that does that, and I haven't heard of any issue. I've done it once. I like hand landing better myself but more often than not I do a proper landing.
2019-12-20
hallmark007
Flight distance : 9827923 ft
No downside, just turn 90 degrees and your good . I think you see very little documented about this because manufacturers don’t want to be seen to encourage hand catching .
2019-12-20
WSUPolar
Flight distance : 2241375 ft
That the only way I “land”
2019-12-20
Ice_2k
Flight distance : 1132575 ft
Romania
I don’t get it, why is this “more convenient” than instructing the mini to land in your hand and catching it like that? Seems like having the drone fight you and requiring a much stronger grip on it to ensure not dropping it are not really “convenience features”
2019-12-21
djiuser_q1uHI6OP3pqW
Flight distance : 914012 ft
Ice_2k Posted at 12-21 06:12
Land it on your hand, simply stretch it out? Keep your descend stick down and it will land and power off
2019-12-21
Ice_2k
Romania
I personally instruct it to land and then use my fingers to catch the body but keeping the palm spread out is basically the same.
2019-12-21
telecam
djiuser_q1uHI6OP3pqW Posted at 12-21 06:41
How does the landing vision sensor feel about that? It does not get confused between hand and ground?
2019-12-21
Jollyroger Hobbies
Flight distance : 17392 ft
telecam Posted at 12-21 09:50
here is a video to answer your question. This is NOT my video
2019-12-21
KlooGee
Flight distance : 16783757 ft
Why put the extra stress on the motors and airframe and kick in an emergency fault in the sensors.
Just left stick down into your hand and hold until the motors shut down.  It works the same with all DJI drones.  Made a video about this with the Spark about 2 years ago.  Watch at the 14:00 min mark to see the hand landing.
2019-12-21
DowntownRDB
Flight distance : 1722 ft
When I'm using the MM on my boat hand landing is definitely more convenient and safer for the MM.  I simply put my hand out, palm facing up with fingers extended and keeping the descent stick down until it lands safely and the motor powers off.
2019-12-22
S-e-ven
Flight distance : 5922034 ft
Thailand
Do you have to "grab it quick"? I think it lands smooth in your hand, by placing the hand 30cm under it and putting the throttle 100% down (landing)
2019-12-22
DowntownRDB
S-e-ven Posted at 12-22 06:35
I don't grab it at all.  Just let it land and wait for the motors to shut off.  Really a simple operation once you've done it a couple of times.  Key is keeping the descent stick down.
2019-12-22
