Jollyroger Hobbies
Flight distance : 17392 ft
It is a good idea to keep a Gallon size Ziploc and a large bag of rice around. If anything like this happens again, land immediately and power off, remove battery and place both (separately) in the Ziploc bag and rice. Let sit for at least a day unless it was really soaked and then do it for 2 days. Wiping it off with a rag or towel will not work. At that point all you are doing is removing some of the moisture from the surface of the body only. NOT from the internal components which is VERY bad. the Dry rice will soak up ALL the moisture in the entire thing.
The reason why water/moisture is bad for drones and all electronics is because water is a HIGHLY conductive substance. The water beads will form a bridge on electric components causing shorts, these shorts can fry your electronics. Long term effects on electronic components is corrosion which can reduce electrical impulses and power management, degrade performance and generally eat your mini from the inside out. This is why Towel drying is NOT effective.
Also, if you constantly fly in high humid environments, you should dry your mini and battery after every flight in rice. (several hours should be sufficient) This is to protect your investment for the long term. |
