DJI Gamora
Hi, thank you for reaching out and we're sorry for the inconvenience. A display that’s 14 inches or bigger is recommended for the calibration. Also, Set the display’s resolution to the recommended default value. (Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.). If one image becomes black or grey, then the sensors are damaged. In this case, I will highly recommend contacting our support using the link below to start up a ticket. Thank you for your understanding and support!
https://www.dji.com/support |
