Matthew Dobrski
Flight distance : 1831050 ft
1. You can adjust sticks expo curvatures to get somehow less abrupt response. And a lot of practice ...
2. 45mm lens is the most prone to exhibit jello on video footage. The one and only way to eliminate jello to a minimum is to keep shutter speed 2x the frame rate and fly slowly. Make sure that silicone suspenders are in good shape. These, however, may get a bit stiff in low temp, if that's the case. |
