Ray-CubeAce
DJI-Osmo-User-1 Posted at 12-23 13:46
You mean Amp, not watt. If you want to see what’s happening with your charger buy a usb power monitor, there very inexpensive and show exactly what’s going on in regards to the power consumption ie charge state.I use this one but there are many much cheaper https://www.amazon.co.uk/Voltmeter-Voltage-Multimeter-Multi-Function-Detector/dp/B07DCT9XSL/ref=sr_1_7?crid=41SMFJZ1B9H0&keywords=usb+power+monitor&qid=1577137647&sprefix=USB+power+m%2Caps%2C162&sr=8-7
Yes, Apologies, Amps not watts, slip of the keyboard late at night.
USB-3 should be fine or if you dare USB-C but I'm not sure if the voltage would be correct as it could go up to 20v with USB-C so unless you are super sure of your leads I wouldn't personally risk that. I bought a couple of leads from Amazon Basics that's allowed me to do that and it charges almost as fast as using a normal wall charger. |
