There are apparently tests of pre production samples. With an additional load of 113 and 124 grams!
There is already a production model. With an additional load of only 57 grams!
I have similarly, under flight within exposure with protection of propellers, additional 56 grams and MM is beginning to constantly issuing mistake "Not Enough Force/ESC Error", beat about the surface, trying to soar and yaw in horizontal a plane.
I do not understand, in it the new firmware is guilty, OR simply pre-serial samples were completed with more qualitative details, than serial?
Hi. Thank you for reaching out to DJI Forum and thank you for sharing this informative video and your insights with regards to this matter. With regards to placing third party accessories. Just a friendly reminder DJI does not recommend to use any third party accessories because this may affect the performance and stability of the said drone and might cause an incident which may void the warranty of the said drone. For the " Not Enough Force/ESC Error " are you flying the drone on S mode when the DJI 360 propeller guards are installed? Is the payload mode enabled when you are encountering this error message? Please keep us posted for further assistance. Thank you.
