mamigacz
I hit a tree about a month ago. The drone was laying in the grass when I found it. On first inspection, one landing leg was broken and the plate that secures the gimbal to the body had an ear busted off. Also, the antenna wires and the harness that attached to the gimbal needed to be replaced. I bought all the needed parts and installed. The drone turned on and did what it normally does on start-up. However, I noticed the camera was not pointing forward. I then noticed that the yaw arm was bent. I bought a cheap yaw arm and ribbon cable (even though the original was not damaged) from amazon. Watched the YouTube video and installed the arm and cable. Should of read the reviews, arm installed and worked fine, cable was an issue. Next, I bought a DJI ribbon cable ($60). Installed it and the camera is going crazy. I watched some more YouTube videos and checked some common issues (see the attached pics). Everything seems to check out. Please watch the video and check out the pictures. Is there anything I’m missing? FYI - I never connected the antenna cables, secured the gimbal with tie wraps, I wanted to be sure there wasn’t an issue before buttoning up everything up. |
