Best video upload
5520 19 2019-12-26
Bojan Blažek
Flight distance : 39167 ft
Croatia
Greeting!
How best to upload a video to youtube so that 2.7k video resolution can be selected? When I process a video with the DJI Fly app is it 1080 HD? Need some simple recommendation. Thank you!
2019-12-26
Dean01
Flight distance : 15513100 ft
South Africa
use another video making app - dji app seems to have a limitation on output quality- try filmora go. Or edit in da vinci and upload
2019-12-26
JodyB
Flight distance : 302536 ft
Dean01 Posted at 12-26 13:09
I've uploaded straight from the sd card filmed in 2.7k and youtube has yet to give me a selection of 2.7 k. 1440 is the best I've ever got from youtube. I can't seem to figure that out either.
2019-12-26
DJI Paladin
Flight distance : 318 ft
Hi. Thank you and welcome to DJI Forum. I hope that our valued DJI members can provide you the best recommendation for this inquiry. Thank you for your valued support.
2019-12-26
gruszon188
Flight distance : 30997 ft
Poland
Did u wait some time after upload? When I upload some video in 4k it take some time before it its possible to watch it in 4k. In one hour after upload its possible to watch in HD only..
2019-12-26
fansef4ae8a7
Flight distance : 19885 ft
Are you using the cached video file or the actual file from the sd card inserted in the drone?
Try downloading the video from the sd card to your computer, edit it and then upload to YouTube.
Also YouTube can take up to 48 hours to render the highest quality video. Sometimes I won't see even the HD version for a few hours.
2019-12-26
Geebax
JodyB Posted at 12-26 13:13
I upload all my clips to YouTube in 4K, and I get 4K versions. YouTube takes into account your link speed in what resolution versions it offers you, and as noted by two of the posters here, YouTube does a lot of processing once the upload finishes, and as the other resolution versions are created, they become available. The highest resolution versions are processed last. 2560 x 1440 is 2k because the horizontal resolution is over 2000.
2019-12-26
ABeardedItalian
Flight distance : 1063107 ft
1440p is the max we get unless we upscale to 4k in post process.
1440p is 2560x1440 and our video is 2720x1536 so youtube scales it down to the closest resolution.
2019-12-26
JodyB
ABeardedItalian Posted at 12-26 13:44
Yeah, I know it don’t make that much difference unless you up it to 4K. Just an ocd thing of mine I guess, lol
2019-12-26
DAFlys
If you are watching on an apple device Youtube limit the resolution to 1080,  you'll need to be in chrome I believe to see the full resolutions.
2019-12-27
Bojan Blažek
Croatia
Thanks for help!
2019-12-27
Mkurr
Flight distance : 1605564 ft
I use filmora pro...
2019-12-27
JodyB
DAFlys Posted at 12-27 00:49
I always use the youtube app on my apple devices. I can select the resolution like when I'm using a PC that way.
2019-12-27
DAFlys
JodyB Posted at 12-27 06:09
You can select a resolution but you are limited to 1080p as YouTube uses a proprietry codec they call VP8 and and VP9 which is not supported on apple devices, and they refuse to use apple supported codecs or port it across.
2019-12-28
JodyB
DAFlys Posted at 12-28 08:04
Hmmmph... I could of sworn I was watching something in 1440 the other day but it looks like you are right my friend
2019-12-28
DAFlys
JodyB Posted at 12-28 12:37
Sad isn't it,  we have devices that have very high res and high quality screens and Youtube pulled support.
2019-12-29
Matt Wang
China
As I know, YouTube does not support 2.7K (2704x1520), dude. Check this table to see what resolution is supported on YouTube.
If your drone didn't record video in 4K or 2K (absolutely there is no 2K option in DJI drone), you can change the resolution in post-editing
Hope it helpful
2020-1-2
DowntownRDB
Flight distance : 1722 ft
+2 for Filmora Pro
2020-1-2
fans8af32c99
Flight distance : 7608 ft
Argentina
Today I recorded a 10min 4K video in with new DJI Mini 2. When I checked the SD Card in my computer it was split in 2 4Gb long, so I tried to patch them together with the DJI software, but they had been reduced to 1080 resolution in my cel phone. So I downloaded Lightworks free version, it worked fine, but could only be exported in 720 resolution, so it was uusable. What is the smartest cheapest way to upload footage from Mini 2 larger than 4Gb in 4K to Youtube?
2021-4-25
djiuser_e7oCwcMIfcu9
DAFlys Posted at 2019-12-27 00:49
Thanks for the Chrome tip.  I’m on a 2022 MacBook Pro.
2023-5-22
