Phoebe Joshua
Flight distance : 80364 ft
As one of the drone beginner pilots, I've learned a couple of things which I put them below:
- (If possible) Always calibrate your drone compass before your fly the drone.
- Don't take off from the grass, you might get the error message for your gymbal. Always take off from a flat surface, to avoid error message of the gymbal.
- Don't take off / landing on the sandy surface as the sand particles will get inside of your DJI Mavic Mini.
- Download and always check the app called 'UAV Forecast' before you fly the drone. DJI Mavic Mini is very limited of 2 things, the WiFi connectivity and the wind gust. Even when the app says 'Good To Fly', if the wind gust is equal or more than DJI Mavic Mini max speed (Sport mode - around 40 km/h), don't fly the drone. You also need to have at least 10-12 satellites to have a good flight.
I also almost lost my DJI Mavic Mini during my 1st 'out of line of sight' flight, in a windy condition (wind speed around 30 km/h, however the wind gust was more than 50 km/h). The higher the altitude, the stronger the wind would be. The video link is https://youtu.be/oLdNpUAU0WU
FYI - even though in some regions, DJI Mavic Mini has a maximum distance of 4kms, I only manage to flown up to 1km (used an antenna booster and an altitude of 60m) in a dense population where WiFi interference does exist. You could find the footage in https://youtu.be/xtycinBvle4
Also note that this drone is for beginner users only, like me. If you could lower your expectation of having a longer distance to fly (due to its WiFi connectivity) and able to fly in any situation (limitation of max speed when fly during windy situation), you will be able to enjoy the other benefits this drone offers (longer battery life, portability - small size, and others).
Hope it helps. |
