Focus wheel zooms instead of pulling focus on my Sony A7iii
278 8 2019-12-27
chilledinlife
India
So I was very excited to try the focus pull feature on the ronin s after watching a lot of videos.
I updated my Sony A7iii to version 3.10 (latest firmware as of today) and my Ronin S to version 2.1.1.0 (latest firmware as of today).
I balanced the gimbal, put on my lens, turned off auto focus only to find out that the focus wheel is zooming in instead of pulling focus.
Can someone please help me. This is urgent. I have a shoot next week and need to get this fixed before that!
2019-12-27
imattis047
I had to get the MCC-C USB C cable. If you have the MCC-Multi, focus pulling will not work. Also, the AF/MF switch my FE 1.8  85mm needed to be set to AF. Good luck.
2019-12-29
Hi chilledinlife, may we verify which cable are you connecting? If you would like the pulling focus function, please connect with the MCC-C cable, and then make sure the settings are correct. Sony A7 iii.png
2019-12-31
Capman81
hello i have sony a7III with ronin SC with focus wheel and i want to control the zoom and not the focus but i don't know how to change this ? thanks
1-5 06:40
M2Wair
Flight distance : 1132149 ft
Capman81 Posted at 1-5 06:40
Which lens are you using.
1-6 16:43
Capman81
M2Wair Posted at 1-6 16:43
hello sony Fe 35mm 1.8 . before a firmware update of ronin SC focus wheel controling the zoom of my A7III and 35mm 1.8 . And now after update of ronin it's controling the focus . But it's so laggy and i prefer use it to control the zoom . thanks
1-7 23:19
M2Wair
Capman81 Posted at 1-7 23:19
So you want to use the focus motor, correct and not the focus wheel!
To change from zoom to focus you need to change cables, if memory serves correct, give it a try. All are in the box.
1-8 05:44
Capman81
M2Wair Posted at 1-8 05:44
Thank you it works with the sony cable suddenly. But why is there not a way to choose between the 2 modes directly on the application with the same cable?
1-8 07:02
M2Wair
Capman81 Posted at 1-8 07:02
My guess its a Sony issue
1-8 15:23
