lannes
Flight distance : 4465 ft
You could just hook up a battery powered monitor or FPV googles via HDMI cable, these will have the lowest image latency
The monitor won't have the brightness unless it's high end, that's why the goggles are a good option
You might be able to connect the two CS units wirelessly but you would need a wireless network running and the latency to the 2nd CS will be quite high
Also messing around with side loading and getting googles services to work is a waste of time on the CS
I've made this work from a ipad mini to Epson BT-300 glasses using the AirScreen app
