Hi there, please follow the below steps to troubleshoot, thanks.
1. If the in-app beginner flight tutorial is used, exit the tutorial and try again.
2. Check the GPS strength in the app. If the GPS signal is weak, try to take off the aircraft in an area where the GPS signal is strong. Ensure that the propellers are in normal condition.
3. When the GPS signal is strong, calibrate the IMU. You can go to Settings>Safety>IMU Calibration and perform calibration following the on-screen instructions.
4. Restart the aircraft.
5. Please check the aircraft firmware version and DJI Fly app version. If there is a new version available, please update to the latest version and try later. If there is no new firmware available, it is recommended that you refresh the firmware again to see if it can be resolved.
6. If the issue cannot be fixed, please contact our support team via http://www.dji.com/support for further assistance. |
