Geebax
DJI4Survey Posted at 1-5 17:57
Hey fansbcb29bc3,
Our failure occurred at 100m, 7m56s into the flight. 64% battery. We do not see the sudden voltage drop in the log. It shows all good at time of failure, all cells balanced and operating normally.
"Our failure occurred at 100m, 7m56s into the flight. 64% battery. We do not see the sudden voltage drop in the log. It shows all good at time of failure, all cells balanced and operating normally."
That is pretty much what happens with a connector failure, everything looks OK up until the whole aircraft shuts down. And it won't write anything about it in the log because the whole thing is suddenly without power. The connector issue has been around for several years, and is isolated to the P4 series aircraft. The previous model, the P3, had a much more robust spade connector design for the battery connection. If you go back over earlier posts on this forum, you will see quite a lot of photos of melted connected and burnt connections, just like the photos in thisa post, only worse. |
