Hi Blake, in general, Sports Mode will increase the voltage drop speed of the battery, and the battery will evaluate its status according to such a voltage drop rate (consumption rate), and it will prompt 'Battery cells under voltage, replace battery' when the voltage reaches a low level.
You mentioned you flew the first battery when the outside air temperature was -1, the recommended operating temperature range of Mavic Mini is 0° to 40°C. Please fly the drone in the recommended temperature. |
