Droneflier
Flight distance : 1811322 ft
South Africa
https://www.phantomhelp.com/LogViewer/6OGQ3HOB1Z9F1782NWXU
DJI Technical please look into there may be a bug in sport mode with the MM
I discovered yesterday when I flew 200 meters out at a constant height of 50 meters in Sport Mode and low light conditions (Sensors where not showing any problems yet), on returning I noticed that the drone was coming back to me as expected with me holding the right stick all the way up, however the MM was also dropping in altitude with out me touching the left stick. I pushed the right stick up to get the MM heading back to me and the same happened the drone moved towards me but also lost altitude at a fair rate. Thinking maybe this was just a once off I sent the MM out same height and distance and the same happened again. I have trees around 15 Meters high around my house and this could potentially be an accident waiting to happen should I loose sight of my MM.
